Ulei cutie de viteze si diferential
  • 0 Răspunsuri
  • 4246 Vizualizări
Vlad
  • 144
  • +17/-0
  • Generatie: NCFL
« : Februarie 07, 2018, 01:22:37 p.m. »
Pentru transmisie trebuie folosit 75W/90 GL4 Fully synthetic. In cutia de 6 viteze intra 2.3 litri iar in cea de 5 viteze intra doar 2 litri.
Uleiuri folosite:
  • Castrol Syntrans MULTIVEHICLE 75W90 Fully Synthetic: epiesa / autodoc24
  • Red Line MT90 - nu prea se gaseste in RO, dar se poate incerca aici
P.S: Merge GL5 sau GL4/GL5 in cutia de viteze? Raspuns aici
Pentru diferential se foloseste 75W/90 GL-5 Fully synthetic. 1 litru este deajuns desi se folosesc doar 0.7-0.8L la NC.
Uleiuri folosite:
  • Red Line 75W90 LS GL-5: aici
  • Liqui Moly GL5 SAE 75W90: aici
Citat
Mk1 early 1600, up to 1994 - 0.65 ltrs
Mk1 Models 1600/1800 1994 on - 1 ltr
Mk2/2.5 Models 1998>2005 - 1 ltr
Mk3/3.5/3.75 models 2005>2015 - 0.7 ltrs
Mk4 Models 2015> - 0.6 ltrs
Please note, the Mk3 diff was filled with 0.7 ltrs at the factory plus or minus 0.1 ltrs. This should leave the oil level 10-12mm below the level of the fill hole which is quite acceptable. If however the the oil is filled up to the level of the fill hole, it will not have any adverse effects on the function or performance of the vehicle. All Mk1,Mk2/2.5 models should be filled to the fill hole level.
P.S: Mobil1 75W90 GL-5 este bun pentru diferential LSD? Raspuns aici
Tutorial pentru schimbul de ulei transmisie si diferential:
« Ultima Modificare: Iunie 23, 2020, 03:36:14 p.m. de Vlad »
